ISE MyDevices Portal customization (remove the column for pending/register state)
anvolkov
This is for ISE 1.3+
do you know if it's possible to remove the Device registration status from the MyDevices portal (ISE 1.4)? By default the status is displayed (Registered/Pending). My Customer wants to get rid of this column in general:
19 Replies 19
please open a new thread as its not directly related to this.
Also would recommend working with the TAC if something is working then stops working likely a bug
It's directly related to this thread, the scripts aren't working for me. We have never gotten them to work. I was just providing the version for color.
You said they disappeared which is a tac issue, please open a new thread instead of back and forth on this
That's what this thread is for. remove column for pending/ register "state"
