Register for the monthly ISE Webinars to learn about ISE configuration and deployment.
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
443
Beginner
ISE posture check fails
hi, we have a problem with posture failing when the PC is connected behind the cisco ip phone. The problem is like this:
the ip phone powered via PoE suddenly loses connections and turns off -> port is down. So the port on PC goes down as well.
When the phone powers up, the port on the PC goes up as well and the whole process starts -> authentication and posture check. The problem is that during the boot up process of the phone, the phone goes down again (seen on the switch and PC) but the posture is still in progress and sometimes it tries to send the result of the posture check when the port is down so the posture fails with notification Failed to contact policy server. Contact your system administrator. There is also Try again button to run the posture again. And sometimes the posture finishes successfully. Is there any way to set up some kind of backoff timer and start the posture check 15seconds after the interface goes up?
thank you
Everyone's tags (6)
1 ACCEPTED SOLUTION
Highlighted
Re: ISE posture check fails
Discover timer values from agent side are very much hard-coded and not configurable via UI, I would recommend exploring the option of posture-lease with PRA of min values
Imran
4 REPLIES 4
Highlighted
Imran
Beginner
Beginner
updated post with video
I would suggest you work with the tac on debugging and coming up with a solution to this
They will look at agent logs suggest fixes and open bugs where needed
