ISE Posture disk encryption check for all drives
Eric Pineda
Is it possible for ISE to check all internal drives for disk encryption? Currently you can specify to check system location or a specific location, is there anyway ISE could check all the drives or at least those supported by the encryption software?
Thanks, Eric
imbashir
It will be possible in ISE 2.4
imbashir
Thanks Imbashir,
Follow up question what mechanism does ISE use to scan all internal drives, does it query all the mapped drives against the encryption software? Will it simply skip un-encryptable drives such as cdrom drives?
