Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
79
Highlighted
ISE Remediation Zone Proviosing on Wireless
Dear All,
I am new to ISE and we are deploying ISE 2.3 in our environment. We have an employee SSID on which we are trying to do posturing.I have following queries:
1. If a client is not compliant  then is it possible to put that client in a remediation zone/quarantine zone where he will first remediate by updating critical updates from SCCM and some other policies. Will that client have a separate subnet in remediation zone? How to achieve this?
Everyone's tags (4)
1 ACCEPTED SOLUTION
Re: ISE Remediation Zone Proviosing on Wireless
Yes this is possible by returning in an authorization profile the name (preferred) or number of another VLAN
https://supportforums.cisco.com/t5/aaa-identity-and-nac/ise-authorization-profile/td-p/2025137
Recommendation is to use Scalable group tags and segmentation instead of VLAN changes.
1 REPLY 1
