05-31-2018 01:38 AM
Dear All,
I am new to ISE and we are deploying ISE 2.3 in our environment. We have an employee SSID on which we are trying to do posturing.I have following queries:
1. If a client is not compliant then is it possible to put that client in a remediation zone/quarantine zone where he will first remediate by updating critical updates from SCCM and some other policies. Will that client have a separate subnet in remediation zone? How to achieve this?
Solved! Go to Solution.
05-31-2018 02:56 PM
Yes this is possible by returning in an authorization profile the name (preferred) or number of another VLAN
https://supportforums.cisco.com/t5/aaa-identity-and-nac/ise-authorization-profile/td-p/2025137
Recommendation is to use Scalable group tags and segmentation instead of VLAN changes.
05-31-2018 02:56 PM
