ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
110
Beginner
ISE serial console RJ 45 port
Does anyone know how to make the RJ 45 serial port on the back of a 3615 ise server not spit out garbage? yes, it's set to 9600 baud, etc.
2 ACCEPTED SOLUTIONS
Highlighted
VIP Advocate
Re: ISE serial console RJ 45 port
Hi Jessica
I have never worked on that server series but I would hope it's the same as all the others.  I found out that the serial port is linked to the OS, and not to the CIMC.  This means that if the OS (ISE/Linux Redhat) is not installed/running, then the port will not respond with anything. If ISE is installed and booted, then by all means the serial port should be linked to tty (console) of the Linux OS.  And 9600 is the default.
Have you dug through the CIMC CLI commands at all to see whether you can flip between CIMC CLI and OS Console?  it is possible.  Have a look here. It's probably not what you're after, but it might be another means to access the console.
Out of curiosity, why are you keen to use the physical console port on the SNS server?
Beginner
We often use the console during upgrade. We do have CIMC working as well. Turns out you have to disable serial over LAN in the CIMC to make the serial console port work
3 REPLIES 3
Try 115200 may be?
Highlighted
VIP Advocate
Hi Jessica
Beginner
