09-06-2018 11:40 PM
Hello Team,
Do we have any info on state machine for sessions on MNT ?
I would like to know:
- for how long the session will be maintained in Authenticated state if no accounting messages are sent (was it 5 days ? configurable ?)
- what is the difference between Started and Authenticated status ? (I have feelings it's not just accounting message?)
Michal
Solved! Go to Solution.
09-07-2018 08:59 AM - edited 09-07-2018 01:59 PM
If ISE receives RADIUS authentication request and:
- If no accounting message is received, ISE maintains session for 1 hour.
- If accounting message is received, ISE maintains session for 5 days or until accounting stop is received. Receiving interim update will renew the 5 day period.
Above settings are hard coded.
Started session means ISE received matching accounting start message.
Authenticated session means ISE got authentication request without accounting message.
