Register for the monthly ISE Webinars to learn about ISE configuration and deployment.
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
231
Highlighted
ISE setup using a Load balancer
We want to setup ISE PSNs behind a loadbalancer( Netscaler or F5). For COA, do we need to add default route on PSNs towards loadbalancer IP? How should we route traffic from PSNs if we are using SNAT, i.e. default route should be towards ? If we are using SNAT, how will PSN determine the IP of NAD device? I am not sure of ISE 2.3, but till ISE 2.2, ISE doesn't have the capability to get the real NAD IP from Radius header. It uses the IP header info to determine the NAD IP.
I see some documents mentioning SNAT is possible for COA? But I don't see how it works?
Any suggestions/links will be really appreciable...
1 ACCEPTED SOLUTION
Re: ISE setup using a Load balancer
Did you look at our F5 doc in the community?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiI84nd9LjWAhXB54MKHaDTB7QQFgg0MAA&url=https%3A%2F%2Fcommunities.cisco.com%2Fdocs%2FDOC-68198&usg=AFQjCNGkPpG_T9t2A8hsHRgz73zTxMFqig
1 REPLY 1
