10-03-2018 07:21 AM
Hello
Is it possible to change the URL of the help link from the ISE sponsor portal.
By default it is: https://ise.myportal.com:8445/sponsorportal/help/b_spons_SponsorPortalUserGuide_en_us.html
If not, can I remove the help link from the site and also from the upper right menu.
ISE version 2.2 patch9
Solved! Go to Solution.
10-10-2018 02:24 PM
10-12-2018 10:32 AM
12-04-2018 11:30 AM
12-06-2018 04:16 AM
10-03-2018 07:49 AM
10-03-2018 11:54 PM
10-10-2018 10:52 AM
10-10-2018 02:24 PM
10-12-2018 10:32 AM
10-15-2018 06:17 AM
Great example. Thank you!
Would be great, if there is a possibility to change to URL of the help link.
10-15-2018 06:25 AM
10-17-2018 08:57 AM
12-03-2018 11:25 PM
Hi Jason,
I've read your article:
However are you sure it works?
I have enter it under below path and running ISE 2.2 Patch12:
Sponsor Portals > [Sponsor portal] > Portal Page Customization > Portal Access > Login > Optional Content 2
But no luck to HIDE or change URL. It still points to the default one.
Also there is a HELP link on the landing page as a page footer but also HELP button in section once sponsor is logged in when you click on the name in right upper corner.
Can you please confirm I have placed script into right section and that it actually works with ISE2.2 P12 ? I have no luck so far to change URL of the HELP to something else (internal).
Thank you
Martin
12-04-2018 11:30 AM
12-04-2018 11:05 PM
Hi Jason,
Yes, Javascript is allowed according to given guideline:
Thank you.
Martin
12-06-2018 03:54 AM
Hi Jason,
I tried to verify that Javascript works with ISE2.2 Patch12 and therefore I used yours example "Exercise 1: Mini-editor move “Don’t have an account” to top of page using JavaScript" and that worked pretty fine, just copy/paste and it worked.
However when I try to hide HELP link or to change URL to something else as described above it doesn't work. I tried to remove also leading indents/spaces into HTML toggle editor but no luck.
Any idea what else to check/test?
Thank you
12-06-2018 04:16 AM
12-07-2018 11:00 AM
