Register for the monthly ISE Webinars to learn about ISE configuration and deployment.
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
254
Highlighted
ise tacacs transations per second report
Is there a way to get a report on TACACS+ transactions per second? A customer would like to see if he exceeds the performance metric or a standalone RADIUS/T+ to decide if he should change his design
1 ACCEPTED SOLUTION
Re: ise tacacs transations per second report
If you customer is running ISE 2.2, the they can pull the TPS from the ISE diagnostic report, however the TPS is not specific to TACACS+
In earlier ISE build, the TPS data can be got via CLI
Copying chyps to keep me honest here.
Cheers!
-Hari
2 REPLIES 2
Cheers!
-Hari
Hi Hari,
The TPS is mentioned in Avg. Can we know the duration of it ?
Hiten R
