Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
109
Beginner
ISE upgrade from 2.1 (appliance) to 2.6 (vmware)
I've read a lot of best practices regarding the upgrade method for ISE and I think the best option is to go with the backup/restore method in my case.
We have an appliance environment of 10 ISE nodes in cluster on version 2.1 that we want to upgrade to a vmware environment on 2.6.
I am thinking of a fresh install of 2.6 on vmware and running a restore of 2.1 here. Then adding fresh 2.6 nodes to the new cluster and assigning them correct personas.
Since we also are giving the 2.6 environment new ip-addresses, it can run in parallel with the 2.1 setup.
Sounds this like a plan?
Are there some pitfalls to consider/watch for?
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Guru
Re: ISE upgrade from 2.1 (appliance) to 2.6 (vmware)
Is there a reason why you want to jump to 2.6 even though 2.4 Patch 8 is the current recommended release?
Your certificates must be carefully considered - make sure you have those exported and verified to include the private key(s).
If you don't have a need for retention, it generally makes sense to purge operational data prior to starting.
Usual advice to carefully follow the upgrade guide always applies.
Other than that, the plan outline sounds good.
3 REPLIES 3
Highlighted
Hall of Fame Guru
Beginner
Thanks for the feedback.
I don't think that 2.6 is that far away from becoming the recommended release, they are already on patch 2. That's the reason for skipping 2.4, and only having to do the upgrade process once. :)
I've managed to test it in stage, and it seems promising. But I've only used the configuration backup though, not tested with operational.
Funfact: The import/restore took 1 hour and 15 min with around 330.000 endpoints in database.
Contributor
This is the general rule I follow, and we are looking to go from 2.3 to 2.6 once that becomes the recommended, but testing I'm having issues restoring with it basically bricking 2.6. I may end up opening a TAC as it is supposed to work.
I definitely recommend spinning up a 2.6 and testing restoring a backup.
