ISE URL MAPPING
nithinrs78901
Is this possible to do Guest url mapping using Cisco ISE.
I need to  dynamically redirect urls that have a certain url structure, maintaining parts of the original URL in the destination URL.
Original URL: https://10.64.67.92:8443/guestportal/gateway?sessionId= 0920269E0000000B0002426B&action=cwa
Mapped URL: https://www.xxxx.com/guestportal/gateway?sessionId= 0920269E0000000B0002426B
If select CWA option under authorization profile, there is a field to enter
static IP/FQDN/Hostname. You can change the guest portal from there.
But we don't need static IP/FQDN/Hostname in the url.we need to show our website.is this possible
Please explain the flow the user is expected to go through and the expected outcome. I am not sure exactly what you’re trying to accomplish
