ISE with Dell Zero Client Solution
Sherif El Shourafah
Experts,
My Customer is looking to deploy ISE within a greenfield environment where DELL zero clients are proposed to them. Do we have any specific guide for this type of deployment that I can share? Our client is against deploying thin clients or traditional desktops where supplicants could be deployed, Do we have any document internally or guide that i can share with my customer ?.
Sherif.
howon
Is there a reason the customer is against enabling 802.1X on the Dell zero clients? I assume the terminals can be centrally managed and configured for 802.1x, and would be the best way for authenticating to the network. If the customer does not want to enable the supplicant on the clients, then they can use MAB (MAC Authentication Bypass) along with whitelist that can be manually populated or dynamically populated using ISE profiling. Then authorize them to the network based on the fact that they are part of the white list. If using profiling, note that profiling provides categorization of different endpoint class/types, but not necessarily the ownership of the endpoint.
Hosuk
howon
Hosuk
In addition to what Hosuk said if they do the whitelist/profile route you should be able to craft a pretty tight DACL for these devices.  I haven't worked with Dell zero clients specifically but other thin client solutions and a very tight DACL was relatively easy to craft.
