02-28-2017 07:57 AM
As I known we don't have ISEv on AWS yet, but for AWS side, they just lauched a solution as hypervisor (VMware) on AWS, so, as for BU or TAC, will they support if customer implement ISEv on hypervisor on AWS?
Solved! Go to Solution.
02-28-2017 10:32 AM
Please see our ISE Compatibility Guides @ http://cs.co/ise-compatibility to see the complete list of hypervisors that ISE supports by version.
If you install ISE onto one of those supported hypervisors with the required amount of cores, RAM, and disk then it is supported regardless of the underlying physical hardware (Cisco, Dell, HP, Amazon, Azure, etc.).
02-28-2017 10:32 AM
