09-12-2019 10:52 PM
I am currently working on ise 2.6 in a lab setup with an order 3750 switch running with v15.0
It appears I have 802.1x and MAB auth working as expected but having an issue with using dACLs and Pre-Auth ACLs to enforce authorisation and access.
In this scenario, I am simulating an unauthorised endpoint - 192.168.2.104 / 0050.562e.f15c. As I've set it in authentication open mode, I am allowing MAB authentication and trying to lock it down via the use of Pre Auth ACL and a dACL with a deny ip any any.
Furthermore, as I am using VMs, I have a number of VM hosts bridged to the single physical NIC on the VM bare metal sever, and have that physically connected to a single port - 1/0/14. As such, I am using authentication host-mode multi-auth.
Once the endpoint is connected (192.168.2.104), I see the correct dACL being downloaded, and appears to be applied, as per the output below.
I've also enabled ip device tracking to ensure the per user ACL is applied. This also appears to be working.
But even through these ACLs seem to be in place, it doesn't actually seem to be blocking any traffic. I've read through a lot of documentation and can't see where I am going wrong.
If I apply a normal extended ACL to a non 802.1x port - it appears to work as expected.
But on the 802.1x port - I can't seem to get the dACL or any ACL to actually block anything.
Below are some config details, with output relating to the host in red
core-01#show run interface gigabitEthernet 1/0/14
Building configuration...
Current configuration : 628 bytes
interface GigabitEthernet1/0/14
description ** ISE LAB **
switchport access vlan 2
switchport mode access
ip device tracking maximum 10
ip access-group TEST in
authentication open
authentication order dot1x mab
authentication priority dot1x mab
authentication port-control auto
authentication periodic
authentication timer reauthenticate server
authentication timer inactivity server
mab
snmp trap mac-notification change added
snmp trap mac-notification change removed
dot1x pae authenticator
dot1x timeout tx-period 10
dot1x pae supplicant
spanning-tree portfast
end
core-01#show authentication sessions
Interface MAC Address Method Domain Status Session ID
Gi1/0/14 ac87.a30b.2d8c mab DATA Authz Success C0A8010100000BFE258C1A69
Gi1/0/14 0050.562e.f15c mab DATA Authz Success C0A8010100000BFF258C1EDE
Gi1/0/14 000c.2922.14a4 mab DATA Authz Success C0A8010100000C00258C1EDE
core-01#show authentication sessions int gigabitEthernet 1/0/14
Interface: GigabitEthernet1/0/14
MAC Address: ac87.a30b.2d8c
IP Address: 192.168.2.6
User-Name: AC-87-A3-0B-2D-8C
Status: Authz Success
Domain: DATA
Security Policy: Should Secure
Security Status: Unsecure
Oper host mode: multi-auth
Oper control dir: both
Authorized By: Authentication Server
Vlan Policy: N/A
ACS ACL: xACSACLx-IP-LABBY_WHITELIST-5d70ae7b
Session timeout: N/A
Idle timeout: N/A
Common Session ID: C0A8010100000BFE258C1A69
Acct Session ID: 0x00000CD0
Handle: 0x28000BFF
Runnable methods list:
Method State
dot1x Failed over
mab Authc Success
MAC Address: 0050.562e.f15c
IP Address: 192.168.2.104
User-Name: 00-50-56-2E-F1-5C
Domain: DATA
Vlan Policy: N/A
ACS ACL: xACSACLx-IP-DENY_ALL_IPV4_TRAFFIC-57f6b0d3
Idle timeout: N/A
Common Session ID: C0A8010100000BFF258C1EDE
Acct Session ID: 0x00000CD1
Handle: 0x34000C00
Method State
dot1x Failed over
mab Authc Success
MAC Address: 000c.2922.14a4
IP Address: 192.168.2.254
User-Name: 00-0C-29-22-14-A4
Domain: DATA
Vlan Policy: N/A
Idle timeout: N/A
Common Session ID: C0A8010100000C00258C1EDE
Acct Session ID: 0x00000CD2
Handle: 0xF3000C01
Method State
dot1x Failed over
mab Authc Success
core-01#show access-list
Extended IP access list Auth-Default-ACL-OPEN
10 permit ip any any
Extended IP access list IPV4_PRE_AUTH_ACL
10 permit udp any eq bootpc any eq bootps (6 matches)
20 permit udp any any eq domain
30 permit ip host 192.168.2.6 any (46 matches)
40 deny ip any any
Extended IP access list TEST
10 deny ip any any log (149611 matches)
Extended IP access list xACSACLx-IP-DENY_ALL_IPV4_TRAFFIC-57f6b0d3 (per-user)
10 deny ip any any
Extended IP access list xACSACLx-IP-LABBY_WHITELIST-5d70ae7b (per-user)
core-01#show ip access-lists interface gigabitEthernet 1/0/14
permit ip host 192.168.2.254 any (3 matches)
deny ip host 192.168.2.104 any (1 match)
core-01#show ip device tracking all
IP Device Tracking = Enabled
IP Device Tracking Probe Count = 3
IP Device Tracking Probe Interval = 30
IP Device Tracking Probe Delay Interval = 10
IP Address MAC Address Vlan Interface STATE
192.168.2.104 0050.562e.f15c 2 GigabitEthernet1/0/14 ACTIVE
192.168.2.6 ac87.a30b.2d8c 2 GigabitEthernet1/0/14 ACTIVE
192.168.2.254 000c.2922.14a4 2 GigabitEthernet1/0/14 ACTIVE
Total number interfaces enabled: 1
Enabled interfaces:
Gi1/0/14
core-01#
But when I am on the host, nothing is being blocked. Below is showing ping but I can access all services - http etc.
When I log the ACL and do terminal mon - I can see some denies being listed - but only traffic to 192.168.1.104 - but nothing from this host. And more so, even through it is saying it's being denied - it isn't actually. Pings for instance work fine and get the response regardless of the logs.
C:\Users\bob>ipconfig
Windows IP Configuration
Ethernet adapter Ethernet0:
Connection-specific DNS Suffix . : labby.local
Link-local IPv6 Address . . . . . : fe80::6943:828e:66d7:a133%7
IPv4 Address. . . . . . . . . . . : 192.168.2.104
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.2.254
C:\Users\bob>ping 192.168.1.2
Pinging 192.168.1.2 with 32 bytes of data:
Reply from 192.168.1.2: bytes=32 time=1ms TTL=127
Reply from 192.168.1.2: bytes=32 time<1ms TTL=127
Ping statistics for 192.168.1.2:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
C:\Users\bob>
I am really scratching my head to why this doesn't appear to be working.
Any help ?
09-13-2019 05:54 AM
09-13-2019 06:29 AM
Thanks for your help.
I tried as you suggested - but funny enough, it seems to have made things worse.
I remove authentication open.
It still authenticates with MAB as expected, and it looks like it has downloaded the dACL.
However, ip device tracking is not longer working and thus the ACL is not being added fully as a per user ACL.
Furthermore, I can still access everything as before. Even with the port extended ACL in place.
I am just stumped on this!!!
core-01(config)#int gigabitEthernet 1/0/14
core-01(config-if)#no authentication open
core-01#sh run int giga 1/0/14
Current configuration : 620 bytes
ip access-group IPV4_PRE_AUTH_ACL in
mab
end
core-01(config-if)#shut
core-01(config-if)#no shut
Gi1/0/14 ac87.a30b.2d8c mab DATA Authz Success C0A8010100000C73288CE408
Gi1/0/14 0050.562e.f15c mab DATA Authz Success C0A8010100000C74288F8904
core-01#show authentication sessions interface gigabitEthernet 1/0/14
Domain: DATA
Vlan Policy: N/A
Idle timeout: N/A
Common Session ID: C0A8010100000C73288CE408
Acct Session ID: 0x00000D48
Handle: 0x04000C74
Method State
dot1x Failed over
mab Authc Success
IP Address: Unknown
Domain: DATA
Vlan Policy: N/A
Idle timeout: N/A
Common Session ID: C0A8010100000C74288F8904
Acct Session ID: 0x00000D49
Handle: 0x74000C75
Method State
dot1x Failed over
mab Authc Success
40 deny ip any any (2 matches)
10 deny ip any any log (177917 matches)
10 deny ip any any
core-01#show ip access-lists interface gigabitEthernet 1/0/14 . <-- shows nothing now
core-01#show ip device tracking all . <-- not trackign any IPs now
Enabled interfaces:
Gi1/0/14
09-13-2019 07:54 AM
09-13-2019 09:28 AM
09-13-2019 10:33 AM
Specifically what model of 3750 and what version of IOS? Just want to make sure it is covered by the compatibility matrix. I have seen similar issues but never on the 3000-series switches. Usually on the 4500 or 6500 chassis where the "show ip access-list int gx/y" shows the ACL there but in the TCAM, the entries were not put in the right order. I forgot the exact command to see how the TCAM is programmed but it is something along the lines of "show platform hardware tcam…..". You may have to do some work to decode it but it shows exactly what is applied on the port. And that issue I mentioned was very intermittent and dependent on the port too. So it would be fine on one port but not work on another. Try moving to another port on the switch to rule that out. And I know you said you have one physical NIC but just want to make sure you don't have another NIC plugged in and doing load-balancing within vSphere. Other than that, try doing some debugs for ip packet detail or EPM. Another possibility is to try removing the pre-auth ACL and try that way. With newer code, the switch will apply a default pre-auth ACL to the port. The ACL is different whether in monitor mode or enforcement mode.
