ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
147
LDAP Messages sent from ISE to LDAP/AD
Hi All,
Would anyone be able to comment in understanding which of these below LDAP messages would be possibly sent from ISE to LDAP/AD? This would be an information which one of my customers is looking out for, and currently we don't have any document which points me to the right direction.
Table 3. Summary Table of LDAP Messages between Consumer and Supplier
The table below lists the common LDAP messages and for each there will be a corresponding detailed Data layout in the following section .
Message #
Message Name
Source/Via/Destination eg. Consumer/Middleware/Supplier
Table Reference
NonUserAuthN
Consumer > Supplier
Table 4
PrimaryUserAuthN
Consumer > Supplier
Table 5
SecondaryUserAuthN
Consumer > Supplier
Table 6
AuthN Response
Supplier > Consumer
Table 7
SearchForUserDN
Consumer > Supplier
Table 8
SearchForUserData
Consumer > Supplier
Table 9
SearchForUserInGroup
Consumer > Supplier
Table 10
SearchForGroupData
Consumer > Supplier
Table 11
SearchResultsEntry & Response
Supplier > Consumer
Table 12
Retrieve User Organisational Information.
Supplier > Consumer
Table 13
CompareUserInGroup
Consumer > Supplier
Table 14
CompareUserInGroupResponse
Supplier > Consumer
Table 15
ModifyRequest
Consumer > Supplier
Table 16
ModifyResponse
Supplier > Consumer
Table 17
AddRequest
Consumer > Supplier
Table 18
AddResponse
Supplier > Consumer
Table 19
DelRequest
Consumer > Supplier
Table 20
DelResponse
Supplier > Consumer
Table 21
SearchForOrganisationalGroupData
Supplier > Consumer
Table 22
Any help or advise on this would be highly appreciated.
Thanks!
4 REPLIES 4
Re: LDAP Messages sent from ISE to LDAP/AD
These do not appear in any of LDAP or Microsoft AD documents I can find on the net so they must be some proprietary messaging used by the customer's application infrastructure and I do not think ISE supporting them at all.
hslai Thank you for the response.
Would you also be able to point me in the direction in understanding the LDAP messages sent from ISE to LDAP/AD? It would also be helpful if a document containing the same could be provided.
ISE is compliant with LDAPv3 ( RFC 451). ISE uses both AD and LDAP for authentications and attribute lookups. If you has partner permissions on the communities, you may check out [ISE Lab Guide] ISE Active Directory Integration.
Highlighted
Thank you very much.
I'll have a look at the ISE LAB Guide.
