02-26-2019 05:40 AM - edited 03-08-2019 07:14 PM
Hi to all,
i have done some searching about this and i only found the following thread:
https://community.cisco.com/t5/identity-services-engine-ise/802-1x-authentication-and-port-security-simultaneously-in-multi/td-p/3482843 but i could not reach to a result by reading this thread.
In addition, as mentioned by Cisco, port-security and 802.1x/MAB authentications are not compatible to each other , so are we in a dead end if we want to use MAB and limit the number of data MAC addresses?
Ditter.
Solved! Go to Solution.
02-26-2019 03:40 PM
02-26-2019 06:14 AM
Hi , with authentication host-mode multiauth you can't restrict the mac address ,the switch will try to authenticate every mac address that switch see on port ,i don't know what is the limit of mac .
If you chose multidomain it will allow you 1 mac address by data Vlan and 1 for voice
02-26-2019 03:40 PM
02-27-2019 04:11 AM
Thanks Damien, i am a little bit confused about MAB in combination with port security.
Probably it depends on the platform of catalyst swithes and/or the IOS?
My current platform is Cat4500 (SUP6L) with 152-2.E8.
Ditter.
02-27-2019 04:59 PM
It could platform specific as you mentioned. Please move this email thread to the switching community.
-Krishnan
