Logging to sponsor portal using Client Certificates
mgrajews
Is there a way to use certificates in order to login to the sponsor portal of ISE? I know it's possible to access the admin UI using certificates, but my customer would like to have the same ability to access the Guest Sponsor Portal.
regards and thanks,
Mateusz Grajewski
Jason Kunst
this is not a current functionality directly, perhaps there is a saml 2.0 provider that can do this and you can login that way?
Jason Kunst
