ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
197
Highlighted
Contributor
MAB Authentication and ISE 2.4 Plus Licencing
I am looking at doing Wired MAB with ISE 2.4. In the past for wireless 802.1x, I have allowed ISE to Profile devices, and then I have set the group to static so that it would not use a Plus license. I am now running into an issue where the wired MAB is using a Plus license.
TAC showed me this information in the documentation.
Plus licenses are supposed to be consumed when profiling-related authorization policies contain: IdentityGroup:Name.
The device that is authenticating is not using profiling to get on the network.
I was wondering if anyone has a run into this problem and can you provide the resolution.
Alex
1 ACCEPTED SOLUTION
Re: MAB Authentication and ISE 2.4 Plus Licencing
3 REPLIES 3
Contributor
I will move my comment to a different thread.
Please move this part of thread to a new question as this has been answered
