05-21-2019 10:03 AM
I am looking at doing Wired MAB with ISE 2.4. In the past for wireless 802.1x, I have allowed ISE to Profile devices, and then I have set the group to static so that it would not use a Plus license. I am now running into an issue where the wired MAB is using a Plus license.
TAC showed me this information in the documentation.
Plus licenses are supposed to be consumed when profiling-related authorization policies contain: IdentityGroup:Name.
The device that is authenticating is not using profiling to get on the network.
I was wondering if anyone has a run into this problem and can you provide the resolution.
Alex
Solved! Go to Solution.
05-21-2019 10:12 AM
05-21-2019 10:12 AM
05-21-2019 10:46 AM - edited 05-21-2019 12:06 PM
I will move my comment to a different thread.
05-21-2019 11:30 AM
