10-15-2019 07:13 AM
Hi All
I have an ISE deployment that was previously two nodes. The secondary node does not exist anymore. I deregistered it already. SInce I have no plans of adding a new secondary node, the next step is for me to make the current node from primary to standalone. Is there any downtime from and endpoint perspective for switching from primary to standalone?
ISE 2.2 Patch 9
Brian
Solved! Go to Solution.
10-15-2019 10:18 AM
Switching from Primary to Standalone will require a restart of the Application Server. I would recommend making the change during a maintenance window or after hours.
10-15-2019 10:18 AM
10-16-2019 05:19 AM
Thanks some endpoints were disconnected for a minute during the switch.
