Max # of posture requirements in one policy
rmueller@cisco.com
Hi all,
within one posture rule it is possible to configure multiple requirements the client has to fulfil to be considered compliant. My customer is asking if there's a maximum number of posture requirements that can be ocnfigured in one rule?
Thanks in advance.
Roland
hslai
EDCS 1565583 shows that ISE supporting the following. It seems possibly to have all 100 requirements in one rule.
Sub TopicISE 2.1 (Carlsbad)Remarks
Posture Policy Rules50
Total checks across all policies (checks used from total defined)200
Total Requirements100If each Posture Policy rule requires one or more posture requirements, then expect # remediation actions to be equal or higher than # rules.
Remediation Actions - one per requirement100If each Posture Policy rule requires one or more posture requirements, then expect # remediation actions to be equal or higher than # rules.
