Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
144
Beginner
NAC Agent download problem
Hello guys,
I am running Cisco ISE v2.4.0.357, and I am implementing Posture making url redirection of user to download NAC Agent from ISE.
When it happends in Firefox browser, it works perfectly, a NAC agent zip file is dwonloaded from ISE whithout issues to install
But if the redirection occurs in other browser, such as chrome or Internet Explorer, It only download a single NAC Agent msi file, not a zip file and the Agent can't be installed. When I click to install it, it prompts the following:
<<This installation package cannot be opened. Contact the manufacturer of the application to verify that it is a valid windows installer package>>.
I've tried in several computers, with diferent browser, the same result.
Any idea?
Thank you in advance
2 REPLIES 2
Highlighted
Contributor
Re: NAC Agent download problem
You mean Anyconnect Posture module (plus Compliance module)?
If yes, make sure your package in ISE Client Provisioning resources contains AnyConnectDesktop package rather than NAC Agent.
Cisco NAC agent is no longer supported, please use anyconnect client with posture module. Also refer to the posture guide https://community.cisco.com/t5/security-documents/ise-posture-prescriptive-deployment-guide/ta-p/3680273
