ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
137
Beginner
NADs behind NAT HIDE
Hello All,
Is it possible to the NADs to do tacacs authentication behind a NAT HIDE?
I have several devices in a site in old fashion way IP addressing out of RFC1918 and it must use NAT. It will use a single IP to arrive in datacenter.
Soon I'll arrange it.
Someone know if it could working fine?
Kind Regards,
Everyone's tags (4)
1 ACCEPTED SOLUTION
Highlighted
Re: NADs behind NAT HIDE
NAT IP address can be configured as a NAD in ISE. But in your scenario you have multiple devices NATTED with Single IP. If you have multiple vendor device operating on your environment then the authorization profile will get collapsed. Single authorization policy will be applicable for those devices.
If you have single vendor you can configure the NAT IP as NAD in ISE and create authorization profile accordingly.
Note: Based on the concept, Not tested any where.
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
1 REPLY 1
Highlighted
