ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
285
Highlighted
NEAT and Native VLAN Setup
Hi Team,
Good day!
This would be a generic question regarding a NEAT setup in the customer's environment. So as per the customer's requirement,
they would like to push a Native VLAN to the Trunk port on the Authenticator Switch. This is required as there is a Native VLAN
mismatch between the Supplicant and Authenticator Switch, which doesn't let the traffic through.  From what I understood in trying
to set it up, I couldn't find any relevant document/article which said a Native VLAN could be pushed from ISE, but however would
like to confirm on the same.  Any inputs or advices on the same would be very helpful.
Thank you!
Mohammed Nazeeh
1 ACCEPTED SOLUTION
Re: NEAT and Native VLAN Setup
Hi Mohammed,
Try this:
NEAT with Interface Template
Cheers!
-Hari
2 REPLIES 2
Hi Mohammed,
Try this:
Cheers!
-Hari
Hi Hari,
Thank you for the response.
It was a doc which I never came across. That really did help me out.
Nazeeh
