10-11-2018 02:28 PM
I'm a little confused about what process to take next, we had a PSN failure where it was offline for an extended period and it was deregistered from the deployment. The node is now back online and still out of the deployment however it's Persona is still as a PSN. Before registering it back to the deployment does this node need to be reconfigured as a stand alone or is it safe to register as is? If so I'm having trouble finding what steps to take.
Thanks for all your help!
Solved! Go to Solution.
10-11-2018 04:09 PM
10-11-2018 04:32 PM
10-11-2018 03:44 PM - edited 10-11-2018 03:46 PM
Just to be safe I would just reset the config on the Node and then re-add it to the deployment and it will sync all the data to the "new" node.
To reset the node just login to the Console and run the following command and reconfigure all the basic info:
application reset-config ise
Note: If you have patched the existing deployment while the node was offline you will need to ensure you add the patch to the node being added to the deployment before it can be added to the deployment.
10-11-2018 03:52 PM
10-11-2018 03:53 PM
Correct, if you are running VM appliance you can just do it through the VM Console so remote is possible in that situation.
10-11-2018 04:09 PM
10-11-2018 04:32 PM
