Passive-ressessment issue
Attila Horvath
Tried to implement 1 day Posture lease time with 4 hours PrA.
If I switch on Reassessment Enforcement, and re-connect  a Compliant machine again to net,
it is force a posture check every time.
At ISE posture logs I see a Compliant entry ("Bypass posture since the endpoint is compliant" ),
but immediately afterwards I see a
PRA INFO: PRA is starting
and after this the client preforms a complete re-check.
Why?
hslai
What you are seeing is expected. Since the initial posture is by-passed due to posture lease, the user will get compliant access right away and then PrA will kick off in place of the initial assessment to start off the timer.
Screen Shot 2017-10-21 at 4.56.39 PM.pngScreen Shot 2017-10-21 at 5.22.52 PM.png
kthiruve
Hi.
Please make sure the you have a authz policy with condition that includes session: Agent-request-type = Periodic reassessment.
Periodic reassessment requires machine to be compliant and also choose the appropriate option when configuring Periodic reassessment
from Administration>System>Setting>Posture>Reassessment, choose the enforcement type continue.
Krishnan
hslai
