PassiveID and CoA
vfranjic
Dear all,
we have customer with ISE 2.4 Patch 7. They are using:
1. 802.1x with Machine Certs
2. PassiveID
Session table in ISE displays UserName as AD username (got that from PassiveID). Problem is when we try to implement CoA switch doesn' react to CoA request from ISE (no valid session found on switch).
When we turn off PassiveID, CoA starts to work properly and Switch reacts to CoA request. Problem is that UserName now is FQDN (got that from 802.1x Machine Cert).
Why is CoA not working with PassiveID and is there any possiblity to make them work together?
Vedran Franjic.
Jason Kunst
I would recommend looking at the following guide
https://community.cisco.com/t5/security-documents/ise-secure-wired-access-prescriptive-deployment-guide/ta-p/3641515
Make sure you have a valid MAB session on the switch.
Look at the guide for easy connect
https://www.google.com/search?q=easy%20connect%20ise%20wired
If still issues work through tac to see what is going on
