Register for the monthly ISE Webinars to learn about ISE configuration and deployment.
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
267
Beginner
Posture check (ISE) over VPN in ASA Muti-Context Mode.
The Perimeter ASA is running in Multi-Context mode and the remote access vpn is working fine, we are now planning to implement posture check (cisco ise 2.4) for RA vpn clients. I would like to know if this is now fully supported? I found a link below which mentions
Remote Access VPN CoA (Change of Authorization) is supported in multiple context mode
(https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-firewalls/200353-ASA-Multi-Context-Mode-Remote-Access-A.html) on ASA9.6(2).
I am hoping that someone has already implemented this scenario and can validate it.
T&R
Arjun
1 ACCEPTED SOLUTION
Highlighted
Beginner
Re: Posture check (ISE) over VPN in ASA Muti-Context Mode.
Update: We got a confirmation from one of our vendors, it is supported.
1 REPLY 1
Highlighted
Beginner
