01-19-2019 06:24 AM
ISE 2.3 patch 5
Is there a way where I can have remediation timer set to different values for different posture checks? For example can I have remediation timer set to 5 minutes for checking if any AM software is installed and a value of 180 minutes for definition file remediation?
Also can I have a user who doesn't remediate AV/AM definition file update initially move to compliant state with "Audit" setting and then move to non-compliant state if they do not remediate after a certain time?
Solved! Go to Solution.
01-19-2019 02:45 PM
01-19-2019 11:26 AM
Yes, under Work Center > Client Processioning > Resource > Posture Agent Profiles Settings where you configure your Agent Behavior there is an option for Remediation timer.
01-19-2019 02:42 PM
Isn't the remediation timer under Posture > Settings > Posture General Settings? I'm already aware where it is. My question is about whether different timer values can be set for different posture requirements instead of a global value.
01-19-2019 02:45 PM
01-20-2019 08:31 AM
Jason is right! this is a global setting and it cannot be different for different posture policy.
Nidhi
01-20-2019 02:49 PM
Thanks Jason, Nidhi for the confirmation.
