Preventing sponsor from creating guest account using certain email domains
scott.stapleton
I want to prevent sponsors from entering an email addresses for the sponsored account that contains a few domains (e.g. - @example.com).
I didn't have luck using the first script detailed here:
https://community.cisco.com/t5/security-documents/ise-sponsor-portal-create-known-accounts-page-customization/ta-p/3636414#toc-hId--1080596999
I had more luck using the second lot of 3 x scripts. However they are written for the person being visited; not the email of the sponsored guest. I've modified the script so that it works on the email address field.
One problem remains; it does the opposite of what it is supposed to do. It is supposed to prevent users entering corporate domain email adddresses (i.e. - black-listing certain domains) but instead it only allows the domains listed in the script (white-listing).
How can the script be changed so that the domains listed in the script are prevented?
See below:
2 Accepted Solutions
sivsivar
Hi Scott,
Please check the script in the below community page under heading "Restrict the email address entered when creating a known account".
Hi Scott,
can you please try the below script.
<script>
    $(document).on("pageshow", function(){
        setTimeout(function() {
            $('.emailAddress').val("");
            var domains = ["domain1.com","domain2.net","domain3.com"];
            function validateDomain(me){
                var idx1 = me.target.value.indexOf("@");
                if(idx1>-1){
                    var splitStr = me.target.value.split("@");
                    if(domains.indexOf(splitStr[1])>-1){
                        me.target.value="";
                        alert("Enter a valid email address.");
                        return false;
            $(function () {
                $('.emailAddress').blur(function (ele) {
                    validateDomain(ele);
        }, 5000);
</script>
9 Replies 9
Jason Kunst
Researching for updated script
Cheers Jason.
@Jason Kunst Did you have any luck chasing down a script?
Still working on it. I was on vacation. Should hopefully have this week
Great - thanks.
sivsivar
Hi Scott,
Thanks - this works although I did need to change the .personBeingVisited to .emailAddress.
One issue however; the script works based on domain; not FQDN. Therefore it blocks domain1.com and domain1.net. I only want it to block domain1.com. I'm unable to specify the FQDN; if I do the script doesn't work. Can it be modified so that the FQDN and not just the domain can be entered?
Hi Scott,
<script>
                if(idx1>-1){
                        me.target.value="";
                        return false;
            $(function () {
        }, 5000);
</script>
This worked well; thanks very much.
