07-29-2019 03:12 AM
In a wired-only BYOD scenario, it is not possible to automatically configure the proxy in the same way it is for wireless?
Don't see the option on the NSP profile.
Regards.
Solved! Go to Solution.
07-31-2019 03:22 AM
As a workaround I configured a dummy SSID profile with the proxy settings, in this way the settings are pushed to the client no matter if no WLAN adapter is present on the endpoint.
07-31-2019 03:22 AM
