PSN node groups and posture
dgaikwad
Level 5
Level 5
Hi Experts,
I am using PSN node groups of 2 PSN in it.
So, when an endpoint authenticates from PSN1 and Posture is run from PSN2, then it should not report NotApplicable as posture status on ISE.
What are your views in case of posture using this PSN node groups? Would they also share the posture session data?
Or is this something that is not yet supported?
Thank you,
hslai
ISE is not currently supporting the use case you are describing.
hslai
If such a configuration is not yet supported, what is the data that is being shared when PSNs are run in a node group configuration?
