PxGrid and checkpoint integration with ISE 2.3
vivekkupekar
One of my client is running ISE 2.2. I am planning to upgrade to ISE 2.3. I wanted to know if PxGrid integration with Checkpoint R80.20 will work in the 2.3 version.
Also how stable is 2.4 version with patch 5?
Vivek
Surendra
This document from Checkpoint states that it does.
https://supportcenter.checkpoint.com/supportcenter/portal?eventSubmit_doGoviewsolutiondetails=&solutionid=sk108235
If R80.20 can integrate with ISE 2.4 as well. So I believe it does for 2.3 as well.
Surendra
Thanks, that was helpful. I was seaching for these details in Cisco's website :).
