Register for the monthly ISE Webinars to learn about ISE configuration and deployment.
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
782
Beginner
PxGrid and checkpoint integration with ISE 2.3
One of my client is running ISE 2.2. I am planning to upgrade to ISE 2.3. I wanted to know if PxGrid integration with Checkpoint R80.20 will work in the 2.3 version.
Also how stable is 2.4 version with patch 5?
Vivek
1 ACCEPTED SOLUTION
Re: PxGrid and checkpoint integration with ISE 2.3
This document from Checkpoint states that it does.
https://supportcenter.checkpoint.com/supportcenter/portal?eventSubmit_doGoviewsolutiondetails=&solutionid=sk108235
If R80.20 can integrate with ISE 2.4 as well. So I believe it does for 2.3 as well.
2 REPLIES 2
Highlighted
Beginner
Thanks, that was helpful. I was seaching for these details in Cisco's website :).
