Pxgrid integration in ISE distrubted envirment
Muhammad Azhar
Dear ISE experts,
I am currently running a distributed ISE setup where i have dedicated PANs,MNTs and PSNs nodes and i have multiple sites.
I am going to integrate a dedicate Pxgrid nodes. Can we enable new boxes for only for PXGRID role  or it will also consider PSN role as well ? Any limitation or design constant that i should consider ?
In future these pxgrid will be use to integrate with security products.
Thanks in advance.
When you build the new node, you can define this as just a pxgrid node. You would register the node into the cluster, you would select the "pxgrid" service and un-select any other role not required.
