pxgrid on PSN node doing radius
danhamil
Quick question for confirmation.
Can pxgrid persona be deployed on a PSN that is also doing radius?  Or if it is deployed on PSN does it have to be dedicated pxgrid PSN and is not able to provide radius/profiling/device admin services?
-Dan
Timothy Abbott
Dan,
It can be deployed on a PSN accepting RADIUS requests however it is best practice for pxGrid nodes to be dedicated.
-Tim
Timothy Abbott
Dan,
-Tim
Thanks Tim.
In the case where the customer only has 1 or 2 pxGrid subscribing clients and doesn't necessarily require a dedicates pxGrid node, is it better to deploy pxGrid persona on PAN/MnT node or PSN node doing radius in this case?
-Dan
Hey Dan,
Please have your customer deploy pxGrid on dedicated nodes.  There may be other caveats if you enable pxGrid on nodes with other personas.
For example, you may run into issues with pxGrid Active-Standby Failover.  If both the pxGrid primary node and pxGrid secondary node are on nodes with other personas. If fail-over occurs, other services may affect how long the secondary pxGrid node comes up.   Also how many concurrent users do you have ad how do you have ISE deployed. What pxGrid solution(s) is your customer looking at implementing and what version of ISE does your customer have.
John
jeppich@cisco.com
