ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
228
Highlighted
Q: Is there a way to fall back from Cert-Based Admin Authentication to Username Password
Received this as an email.  Answering here:
QUESTION:
We are actually faced with customers demand to authenticate ISE admin users by using client certificates.
I tried out this feature in virtual environment and was neither able to use local fallback user nor switch back to password-based auth.
Can you give us a hint regarding certificate base + local fallback admin access ?
ANSWER:
There is no fail-back from Certificate Auth to Password auth.  This is because of the way that SSL Client checking works – when the web page’s SSL is configured to verify the client side & not just have a 1-way trust (normal SSL is client trusts Server, but server ignores client) then the SSL tunnel security the HTTP requires mutual authentication between the client/server.
If that mutual auth fails, the SSL tunnel cannot be formed and the page cannot be displayed in order to fail back to client auth.
-Aaron
Everyone's tags (3)
1 REPLY 1
Re: Q: Is there a way to fall back from Cert-Based Admin Authentication to Username Password
Once cert-auth configured for ISE admin web UI access, the only way to fall back is to stop ISE and restart it with "safe" mode at ISE admin CLI. See application start
application stop ise
application start ise safe
