Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
289
Highlighted
Question about Soti MobiControl
Have a customer testing MobiControl with ISE.  Integration is up and functioning, however the attribute for "MDM Compliant" that ISE can query does not necessarily mean that the device is compliant.  It appears to only look at registration and jail broken status.  Within Mobi, the customer is able to move endpoints to different "folders" depending on application status and compliance (i.e. Missing firewall, AV etc.)
Does anybody know if there is a way to query Mobi to see what folder a device is in?  I would assume this may not be possible as we have specific library attributes for MDM and if the vendor does not populate those correctly, then not much we can do, but didn't know if there was something I was missing or if anybody knew of or had experience with MobiControl.
Thanks!
3 REPLIES 3
Highlighted
Re: Question about Soti MobiControl
I would recommend reaching out to the vendor and ask them why they are doing it this way
Thanks.  Already did, they were not all the helpful and pushed back on us.  Just looking to see if anybody else had any other experiences.  I've personally not seen Soti deployed much.
Thanks Again
Highlighted
OK thank you Cindy comes down to experience other customers or partner has with the vendor
As you have already determined ISE has really no control of that. We simply rely on the attributes that are sent back from them. Maybe the customer would like to valuate Meraki Or another vendor to see if that works better for them.
