Register for the monthly ISE Webinars to learn about ISE configuration and deployment.
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
126
Enthusiast
RADIUS Log not showing
Trying to setup iPSK but having issues not seeing the radius logs, they are not showing.
This is my lab, fresh install of 2.2 with patch 15.
I have seen there was an issue which required patch 4, but I'm guessing that bug fix is in patch 15 as well or do I need to install patch 4.
Compared all settings to live ISE.
The AAA is showing in logging, so doesn't need injecting.
cheers
4 REPLIES 4
VIP Advocate
Re: RADIUS Log not showing
Any fix found in patch 1 through 14 will be included in patch 15 baring any rare regression or mistakes in code. So patch 15 should be what you are on.
Are you seeing anything from the WLC in the ISE RADIUS live logs? If not, are you seeing any alarm on the dashboard for unknown NADs?
Enthusiast
Just checked, not appearing in in Live Logs or Session Logs.
Does appear in Endpoints, and has profiled the 3 devices, also shows in active endpoints.
cheers
VIP Advocate
That's indicative of a database issue on the ISE MNT side of the house. I am currently working with TAC on a similar issue but am not far enough along to provide any helpful information.
I would also recommend you open up a TAC case for this, the symptoms you mention indicate an underlying issue we very likely won't be able to solve on the forums.
Highlighted
Contributor
For what it's worth, I've had similar issue in my ISE 2.3 deployments where the MnT stopped collecting data and the system health would shown unavailable for nodes. Rebooting the MnTnode fixes the issue, but haven't found a root cause yet.
