ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
89
Beginner
RBAC and Endpoint delete issue. There was an error while deleting all the records.
ISE 2.2 Patch 13 and Endpoint delete issue.
I did setup RBAC policy Menu + Data for Admin User with limited permissions.
When this Limited Admin logins and try delete endpoint under the menu: Content visibility > Endpoints it got an error message: "There was an error while deleting all the records. See logs for more details"
Limited Admin has Full Data Access to Endpoints Identity Group.
When Super Admin tries to delete endpoint it succeeds.
What should be a problem with RBAC settings?
Where are the logs for more details? I did not find any logs under Reports menu.
Thank you.
1 ACCEPTED SOLUTION
Highlighted
Beginner
Re: RBAC and Endpoint delete issue. There was an error while deleting all the records.
It's is bug CSCvf33851
The affected release is also ISE 2.2.0.470.
The workaround is working as well in this case.
Problem solved.
ISE Admin User with limited access can now delete EndPoint from a table in Content visibility > Endpoints menu.
1 REPLY 1
Highlighted
Beginner
Problem solved.
