08-19-2019 05:21 AM
Folks,
We have to work on a rebuild the SNS 3515 by installing the 2.3 version from the existing 2.4 version. This is a new install and the devices got shipped with the 2.4 version.
We went through some documentation in the below link:
Below questions:
1. Now, the question I have is should we first configure the CIMC port? If yes, how? We are having a tough time getting the F8 option and then getting the options on the console.
2. What is the use for the KVM console then? Is that console going to give us the boot options after the CIMC is configured?
N!!!
Solved! Go to Solution.
08-25-2019 03:13 PM
Yep - VGA and USB is the safest option. If you get "no signal" on your monitor then press a key on the keyboard to wake up the display.
08-19-2019 02:15 PM
It's a bit of a lengthy explanation and it's all well documented.
You have two ways to manage a UCS server (SNS-3xxx)
Real Keyboard Video Mouse (KVM)
Via CIMC (virtual KVM)
08-23-2019 02:45 AM
Hi Arne,
I think I now understand where I was making a mess :)
Let me plug in a real KVM to the ports as you have mentioned and then try this out.
Here are the ports where I would plug the KVM:
Thanks!!
N.
08-25-2019 03:13 PM
09-03-2019 04:24 AM
the solutions provided have helped. :-)
Thanks a ton!! We have our CIMC part up and running now.
