Renaming the authc rule names
Moreplovac
Hello
it must be the way to rename authentication rule names but i cannot find it. I can alter the rule itself, duplicate, delete, set to disable or monitor but for some reason i cannot find the way to rename it.. So all my policies are Authentication Rule number 1, 2, copy of authentication rule 1, ... which does not make much of a sense :-)
Any assistance appreciated.
hariholla
I believe you are using ISE 2.3
hariholla
Thanks; it is actually issues with my browser as well :-)
Appreciated..
