Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
913
Reorder Guest Fields
Do we have a script to re-oder Guest fields, such as move "person being visited"?
Everyone's tags (5)
1 ACCEPTED SOLUTION
Highlighted
Re: Reorder Guest Fields
Here is an example we had on how to move elements.
This can be used for Japanese use case where the last name should come before the first name. This is put in the instructional text field of the Create Accounts for Known Guests under a sponsor portal page.
​<script>
jQuery(function(){
  setTimeout(function(){
  var first_name = jQuery('.firstName').parents().eq(1);
  var last_name = jQuery('.lastName').parents().eq(1);
  first_name.remove();
  last_name.after(first_name);  }, 1000);});
</script>
7 REPLIES 7
Highlighted
​<script>
jQuery(function(){
</script>
Highlighted
What portal page did you want this for? Thinking maybe self-reg page?
Highlighted
Correct, self-registration.
BTW, what are the txt field names for the fields that I need to reference. Is there a reference where I could find the variable names?
Highlighted
You can see the fields under the portal language files (export them at the top right of the page)
Or if you use chrome developer tools to decode the elements
I am working on getting this to work with self-reg, what are the fields you want to reorder?
Highlighted
Sorry for my delayed reply. I am looking to move "person being visited" to the last. Maybe more fields are needed but will wait on the customer.
Highlighted
Highlighted
Thank Jason, will let you know if I need further changes.
Benjamin Gajadar
Network Consulting Engineer
Cisco Security Solutions - Integration
