07-30-2018 03:08 AM
Hi Experts,
As an extension to my previous post, there are further questions that I need for reporting on ISE.
I see that ISE does have a set of reporting capabilities built into it, but I am not able to locate or generate report as these following requirements that I have:
I have tried doing a report export and then using MS Excel to fine tune it, but that becomes a very tedious task when working with hundreds of users and machines.
Has anyone tried this before? Any pointers will help.
Thank you,
DG
07-30-2018 04:12 PM
07-31-2018 01:26 AM
Yes, I have been manipulating the report using Excel, but then there are certain specific requirements from the client, which the reports that already ISE provides does not suffice them.
Since, you mentioned that you are using internal tool to manipulate these reports, would it be possible to share that information as off how its done.
And as off now is this enhancement being confirmed for future releases as well?
