Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
128
Restoring ISE 2.2 Backup to ISE 2.6
Is it possible to restore a backup from a version 2.2 ISE to a Version 2.6? Or would I neet to upgrade the 2.2 VM/Appliance?
1 ACCEPTED SOLUTION
Highlighted
VIP Advocate
Re: Restoring ISE 2.2 Backup to ISE 2.6
Yes you will be able to take a 2.2 backup straight in to a 2.6 node, 2.6 will accept a backup from 2.1 or newer.
At the same time, if you have not already run the URT while on 2.2, it's possible that differences in the data structure could cause the restore to fail. The data in the backup goes through the same upgrade that it would if you were to upgrade a 2.2 node to 2.6.
1 REPLY 1
Highlighted
VIP Advocate
