Sending logs to MnT nodes
Antonio Macia
Level 3
Level 3
At some Cisco talk, I've heard that sending WLC, ASA, or switches logs to the MnT is recommended for richer visibility. What are the real benefits of this and what new information can ISE take from these logs? Will not impact on the MnT node performance?
Regards.
howon
There is small benefit as admin can see the logs from the switches without having to login to each switch. ISE merges the syslog event from the switch with live log. But this is not recommended beyond the pilot stage of the ISE deployment as it impacts ISE load as well as issues with session tracking. Aside from the switch, if ASA sends web access events to MnT, ISE can correlate guest users with web access events from the ASA for guest access log. If using guest access event correlation, make sure to configure ASA to only send web access event as not to overload the MnT node.
5 Replies 5
Jason Kunst
Which cisco live?
This is only for troubleshooting purposes. Please see cisco live information for ISE performance and scale at it says it there under the training links for BRKSEC-3432
https://community.cisco.com/t5/security-documents/ise-performance-amp-scale/ta-p/3642148#toc-hId-118574828
For long term rich logs look into Cisco DNA Assurance and/or splunk
Thank you Jason,
It was at some partner training. I will skip this for the moment then.
regards.
Thank you Jason,
regards.
Can you please share the info with me directly at jakunst@cisco.com
howon
