Spark Bot for guest access
brunatoledo
Hello!
Is there a way to create a Cisco Spark Bot that can create guest users on the network? Using Meraki ou ISE API's.
Thank you!
Bruna T.
Jason Kunst
We have reached out to the maker of this video to see if we can work on some more information and examples. Please keep in mind this is a best effort item we will work on when we have time
Workflow Automation with ISE Bot - YouTube
I know the product manager amekulka is also looking at integration for future roadmap as well.
6 Replies 6
kthiruve
HI Bruna,
If you have the right set of tools and time things are possible. I have not tried it though.
However you could tie in Spark with Guest using API's but think about the use case why you want to do it
and the flow where guests login to a portal upon authentication.
ISE Guest Sponsor API Tips & Tricks
https://www.cisco.com/c/en/us/td/docs/security/ise/2-3/api_ref_guide/api_ref_book/ise_api_ref_ers1.html
Krishnan
Jason Kunst
Have you established any comms with that person? Anything you could share?
I'm not necessarily looking for a complete solution, but some guidance could be a good start.
Working on it , hopefully next week
maybe a few more weeks to get anything to share
Thank you for updating Jason
