Sponsor-portal and licensing
zohaibmuzaffar7
hi
i have two ISE appliances running on version 2.2.470 with patch number 6. The main function of these is that they provide a sponsor portal /guest portal for the wirless guest networks for our different customers. Only one node is running the policy and portal functionality, while the other is only primary monitoring node, along with being as secondary admin . My question is that if i don't have enough endpoint licenses , will portal stop working. Right now my issue is that when users try to access the network, the sponsor-portal doesn't pops-up and they get connected to the network right away.TH portal settings are ok and i have tested it through the test portal functionality but for the end users the said sponsor-portal doesn't  pops-up  Can it be a licensingissue..
need  help/feedback on this .
Jason Kunst
Licensing will not block admin to the guest portal
Please contact the tac to debug
