08-02-2019 09:13 AM
The SNS-3695 is built with 8x 600 GB 10k hard drives, and for a PSN I feel that is fine. Has there been any thought put in to offering an option to replace these drives with SSD's? The primary use case I have in mind is for the monitoring nodes.
Since it is not possible right now when ordering, is there a possibility of field replacing the HDDs with SSDs, understanding that there would be RMA implications?
Solved! Go to Solution.
08-06-2019 06:17 AM
08-02-2019 09:25 AM
- I wouldn't recommend this on an appliance : 1) Even if some has slightly modified the standard disk driver from the underlying OS, you will probably get into trouble. 2) More important ; the product is no longer certified on modified hardware configurations.
M.
08-02-2019 10:01 AM
08-06-2019 06:17 AM
